Could I make in edit an assembly's part?
I'm non expert to program with Solid Edge ST3, I have this problem:
I have an assembly with 2 part, I select 1 part and i' d like to edit this part, write properties and save with name.
I write this code:
Dim oiDoc As SolidEdgeFramework.SolidEdgeDocument
oiDoc = SEApplication.ActiveDocument.SelectSet.item(1).OccurrenceDocument
oiDoc.Activate()
But Activate send me an non specified error, if i try to saveas whitout edit send me it's not possible to save a file.
Someone Can Help me to resolve my problem?
Thanks I excuse me for my english.
Posted by: Serena Meiattini
Post date: 1/6/2011 11:27:03 PM
RE: Could I make in edit an assembly's part?
if you want to save that occurence please call "makewriteable" method on that occurrence,it will works
RegardsPrasad
Posted by: prasad k
Post date: 11/23/2011 1:07:12 AM
