Count Variable in Circular Pattern
heres one for you gurus...
I have created a circular pattern and want to get the count variable to look at a formula e.g. when I add a circular pattern with x instances I would like this value to be driven by another variable.
I have searched all the documentation that I can find, searched through SESpy and found...Nothing
The closest that I have come is the Drawing objects collection of the profile, but this just gives a value as an integer and not the variable behind it.
Does anyone have any clues as to where to go from here?
TIA
James
Posted by: James Singleton
Post date: 5/22/2006 12:10:16 AM
