Count hole in assembly file -- SE V17
Firstly, thank you for this super forum
Secondly, I seek a solution to count the number of hole in an assembly.
I uses a drilling technological assembly function and I do not find any property or function in the SolidEdge API to count the number of hole.
Did Someone can help me ?
Thank you for your assistance
Posted by: c monmail
Post date: 2/27/2006 6:05:11 PM
RE: Count hole in assembly file -- SE V17
I think what you're wanting is possible. I'd have to spend some time looking into it as I don't know off the top of my head.
If you haven't do so already, download my Solid Edge Spy program as it will help you figure out how to do it. In a nutshell, you'll probably have to enumerate through the assembly's occurrences and look for the holes.
I'll try to get you an example in a couple of days.
Posted by: Jason Newell
Post date: 3/1/2006 9:35:03 PM
Hi jason,
Thanks for your answer.
i uses your solid edge spy program, but i do not thound any drilling assembly object in the occurents items [only the diferents part files].
visibly, i thound the drilling technoligical assembly function in :
ActiveDocument
- assemblyFeatures
- assemblyFeaturesHoles
- Items
- 1 -
but i do not have any object function nor property in this sub key.
thanks
Post date: 3/2/2006 12:43:40 AM
