Create a balloon in a sketch
Hi
How do I create a balloon in a sketch using the API?
Dim oSEDoc As SolidEdgeAssembly.AssemblyDocument = Nothing
Dim oProfile As SolidEdgePart.Profile = Nothing
Dim oLine As SolidEdgeFrameworkSupport.Line2d
Dim oBalloon As SolidEdgeFrameworkSupport.Balloon
  oSEApp = GetObject(, "SolidEdge.Application")
  oProfile = oSEApp.ActiveDocument.ActiveSketch
  'Create a line
  oLine = oProfile.Lines2D.AddBy2Points(0,0,1,0)
  'Now attach a balloon to it
  oBalloon = oProfile.???.(???)
Posted by: Pascal Boivin
Post date: 4/15/2010 8:24:16 AM
RE: Create a balloon in a sketch
Or maybe by using a command? Any idea?
Post date: 4/20/2010 3:27:55 AM
Hi Pascal,
It don't really know how to do it, but you could try the following command id;
oSEapp.StartCommand(32856)
This creates a balloon annoatation. For the rest I can't help your, sorry.
Good Luck!
Posted by: Wouter Sloof
Post date: 4/20/2010 4:04:42 AM
