Create a complexstring interactively
Creating a ComplexString2D object is possible using the API.
Is it also possible to create a ComplexString of lines and arcs interactively in Draft ?
As seen in image above, Solid Edge recognizes and handles a complex string created programatically.
There sure should be a way to create one manually. Any ideas ?
The Command Finder yields nothing on searching Complex or String or ComplexString.
