Create a protusion from a sketch programmatically
Hi, I have a problem with a profile in SE Sheet Metal (ST4 in Synchronous Mode).
The profile has been created in SE Draft with a lot of lines inside (ex. a rectangle with a line between tho vertexes).
I've created a sketch and copied the profile programmatically (I see a lot of regions), but I'm not able to extrude it.
I've tried to use AddBaseTab command but I receive an error.
Could you help me, please?
Posted by: Massimo Schinardi
Post date: 10/17/2013 4:52:49 AM
