Create construction circle in code
Question: How to toggle a created circle from profile to construction? Or how to create circle that is already construction? I've tried, but my code doesn't work
Documents documents = app.Documents;
PartDocument partDocument = documents.AddPartDocument();
app.DoIdle();
RefPlanes refPlanes = partDocument.RefPlanes;
Sketchs sketches = partDocument.Sketches;
RefPlane refPlane = refPlanes.GetFrontPlane();
Sketch sketch = sketches.Add();
Profile profile = sketch.Profiles.Add(refPlane);
// Create elements
Circle2d circle1 = profile.Circles2d.AddByCenterRadius(0, 0, DIAMETER_CIRCLE_1 / 2);
Circle2d circle2 = profile.Circles2d.AddByCenterRadius(0, 0, DIAMETER_CIRCLE_2 / 2);
// Execute command "Toggle to Construction" for selected objects
app.ActiveSelectSet.Add(circle1);
app.ActiveSelectSet.Add(circle2);
app.StartCommand(LayoutInPartCommandConstants.LayoutInPartToolsConstruction);
app.ActiveSelectSet.RemoveAll();
Re: Create construction circle in code
Hi kavit,
don't use the select set and StartCommand()!
The Profile object has a method ToggleConstruction(Element)
to change to construction and back. Use your created circle1 object as parameter.
    profile.ToggleConstruction(circle1)
You can also query the construction status by
profile.IsConstructionElement(Element)
regards JB
JB
SE ST10
Awesome, thanks !
