Create draft for .psm using other template
Hi, I succeded in generating draft document for my .psm file using the common draft creating procedure
oDocD = oDocs.Add("SolidEdge.DraftDocument")
But It always generates the draft with the standard ISO metric Draft.dft fro the standard templates. Even if I "specifie another template to be used when a file is automatically created"using the set default template in the solidedge option "helpers". It changes abosolutly nothing and creates again the draft using the ISO metric Draft.Dft.
Please help, Thanks
ST9
Conveyor and industrial equipment designer.
Giving SE a chance.
Re: Create draft for .psm using other template
Hi, Have you checked the second argument for Template Doc.
It's an object but I think you can specify a string with full or relative path to the template doc.
~Tushar
Thanks Tushar!
Kabir Costa
Industrial Designer
kabircosta@gmail.com
Tushar, But how to do this with Quicksheet? To insert the part in views?
Kabir Costa
Industrial Designer
