Create in Place with dialog
I've successfully implemented the  OnCreateInPlacePartUI Event and it works fine.
Now I will place the new part in the same way as the standard SolidEdge Dialog, e.g. referenced to a scetch or with absolute coordinates.
Did some one has an idea how I can do that ? In my first idea I want to open the original create in place dialog with predefined template and filename (filled out by my own routine implemented in the UI event), but I found no method to do that.
Posted by: Christian Sons
Post date: 12/18/2008 12:17:22 AM
