Create principal view
Hi. How can I create principal view in code (see image below)?
Origin image I created by code:
ModelLinks modelLinks = _draftDoc.ModelLinks;
ModelLink modelLink = modelLinks.Add(_fullName);
DrawingViews drawingViews = _sheet.DrawingViews;
DrawingView drawingView = drawingViews.AddPartView(
    Orientation: orientation,
    Scale: scale,
    x: StUtils.MillimetersToMeters(x),
    y: StUtils.MillimetersToMeters(y),
    ViewType: PartDrawingViewTypeConstants.sePartDesignedView);
drawingView.CaptionDefinitionTextPrimary = caption;
How to create a second view (see figure below)? Which method to invoke for an object drawingViews.AddXXXXX ?
Re: Create principal view
I can't currently verify, but in previous releases for ViewType the following misspelled constant had to be used:
SolidEdgeDraft.DrawingViewTypeConstants.igPrincipleView
Kind regards,
Wolfgang Kunert - www.wksyspro.de
just verified what to do.
If you set the orientation to igTopView the resulting DrawingView will get the (readonly) DrawingViewType igPrincipleView.
Kind regards,
