Reply
Current value
I have placed an area sensor in a part file.
Dont know how to use the Object.CurrentValue command to get the current sensor value
Ali Kamran
Re: Current value
CurrentValue is a Property (read only).
So just get Sensor object of your Document and use the value:
 oPartDocument  = oAppl.ActiveDocument
 dim oSensor as SolidEdgeFramework.Sensor
 oSensor = oPartDocument.Sensors.Item(1) ' example, just use the first
 dim SArea as double = oSensor.CurrentValue
 regards JB
JB
VS2015, SE ST10
Re: Current value
Thanks JB
It worked fine.
One more question , if I want to supress the sensor and then unsupress , any idea how to do that ?
Ali Kamran
Re: Current value
I would like to put again the question.
First at time of sensor placement Sensor update should be set to manual Update
later at required instance update it ...
how to do it ?
any ideas please
Ali
Re: Current value
Hi @alikamran,
Three SensorUpdateMechanismConstants enumeration are available on Sensor object.
Member Value Description
seSensorUpdateMechanismAutomatic 1 Automatic sensor update
seSensorUpdateMechanismInvalid 0 Invalid sensor update mechanism
seSensorUpdateMechanismManual 2 Manual sensor update
You can make use it as shown below.
objSensor.UpdateMechanism = SolidEdgeFramework.SensorUpdateMechanismConstants.seSensorUpdateMechanismManual
Kaustubh
