Curve by Table Driven by Equation
My first question is, is there a way to populate/write to the embedded Excel sheet generated with a curve by table command. The command will already exist in the part, I just need to find a way to populate that table without physically opening the table. Preferably through automation and programming. If this has been done before, can anyone link me to where?
Second, is it possible to control/populate a curve by table with an equation? I would prefer to have the curve driven by an equation with the equation having, say, 2 or 3 inputs defined in the Variable Table. Or, if there is a way to write to the curve by table Excel sheet the inputs can be changed that way for the equation.
Re: Curve by Table Driven by Equation
Please see if this suits your needs:
https://community.plm.automation.siemens.com/t5/Solid-Edge-Forum/Equation-Driven-Curve/m-p/293215#M8...
~Tushar Suradkar
fb.pngSolid Edge Users Facebook Group
[ Everything under the sun about - Solid Edge ]
