Custom File Properties..?
Hi Jason,
i want to fill custom file properties to a part file. In Custom tab i want to add "Name" and "Value" through vb.net. i have attached a jpg file. Pls give me code snippet as it is on urgent basis.
Thanks in advance
Prasad Pawar (Design Automation Engineer)
Posted by: Prasad Pawar
Post date: 9/26/2007 9:06:28 PM
RE: Custom File Properties..?
There are already examples for you on this site. Go to the Downloads page and download the "Solid Edge Developer Conference 2006" material. There are a ton of examples in there.
Posted by: Jason Newell
Post date: 9/26/2007 9:26:15 PM
Jason,
it is not getting download. i think there is some prb......other material is getting download.
Post date: 9/27/2007 1:13:22 AM
Can you be more specific about what the problem is? I just tried the download and it worked for me.
Post date: 9/27/2007 8:40:32 AM
To get you going, here is the code.
' Add reference to PropAuto.dll
Imports SolidEdgeFileProperties
Module Module1
Sub Main()
Dim objPropertySets As New SolidEdgeFileProperties.PropertySets
Dim objCustomProperties As SolidEdgeFileProperties.Properties
objPropertySets.Open("C:\Program Files\Solid Edge V20\Training\Coffee Pot.asm", False)
objCustomProperties = objPropertySets.Item("Custom")
objCustomProperties.Add("Name", "Value")
objCustomProperties.Save()
End Sub
End Module
Post date: 9/27/2007 8:47:09 AM
Ohh!! Thank You very much jason......
Post date: 9/27/2007 11:32:04 PM
I have found this forum in the last navigation hour, and I'm finding it very interesting.
I have been registered since 5 minutes, but I can't find the "download" section; it should be very usefull for me to manage custom properties.
Many other posts publish links in the "http://www.jasonnewell.net/portal/Products/" folders, but it seems to me that it doesn't exists.
Thanks for your help
Alessio
Posted by: Alessio Rossi
Post date: 9/29/2007 7:46:58 AM
I think I have found it: it's a bug... with my home linux, with Firefox and Epiphany I can't see the download section. With Konqueror I can
Alessio
Post date: 9/30/2007 5:10:11 AM
Posted By alex on 09/29/2007 12:46 PM
 Hi alex and welcome to the fourms.
That is an old link.  Acutally any link with /portal/ is old.  I switched hosting providers earlier in the year and upgraded the site.  Glad to have you here.
Post date: 9/30/2007 7:18:07 PM
Jason, thank for your answer.
Actually I'm unable to download the "Solid Edge Developer Conference 2006" file, the download stops work at about 90%. I have tried many browser, under windows too.
Does anyone else have this problem?
I can download other files correctly.
Alessio
Post date: 10/1/2007 4:38:09 AM
