Custom Properties - Read only file
Hi All,
I have following situation.
In SE ST4 I have opened one drawing, where model is one part, marked as readonly.
A have VB.NET Addin which
- mark part file as normal
- change custom property
- again mark part file as readonly.
But in drawing changed property has old value, until I open this part.
If I don't mark part file as readonly property is changing, but I realy need have this part as readonly.
thanks for help
Posted by: lu on
Post date: 1/28/2013 5:15:15 AM
try, after update the part property, to call the method
[code type=vbnet]DraftDocument.UpdatePropertyTextCacheAndDisplay[/code]
Posted by: JR
Post date: 1/28/2013 6:33:10 AM
