Custom Properties lock problem
Hi
A have problem with writing Custom properties with SolidEdgeFileProperties.
I can read, write and also delete all properties, but where I Close
PropertySets.Close()
file is still in lock state.
Can any help
My problem function
Public Function WriteCustomProperty(ByVal FileNameWithPath As String) As Boolean
    Dim DocName As String = "", DocPath As String = ""
    Dim myList As List(Of Dialogs.SovaDialogCustomProperties)
    Dim DocPropertySets As New SolidEdgeFileProperties.PropertySets
    Dim DocProperties As SolidEdgeFileProperties.Properties
    DocPropertySets.Open(FileNameWithPath)
    DocProperties = DocPropertySets.Item("Custom")
    DocName = ObjSE.FilePart(ObjSE.FilePart(FileNameWithPath, SovaFileParts.FileNameWithoutPath), SovaFileParts.File_Name)
    DocPath = ObjSE.FilePart(FileNameWithPath, SovaFileParts.Path)
    Dim PropertyKey As String = "", PropertyValue As String = ""
    myList = ObjSE.GlobalListOfCustomProperties(DocName, DocPath)
    For Each DocProperty In DocProperties
      If UCase(Left(DocProperty.Name, 4)) = "SPM_" Then
        Try
          DocProperty.Delete()
        Catch ex As Exception
          MsgBox(ex.Message)
        End Try
      End If
    Next
    For i As Integer = 1 To myList.Count
      Try
        DocProperties.Add(myList.Item(i - 1).PropertyName, myList.Item(i - 1).PropertyValue)
        MsgBox(ex.Message)
      End Try
    Next
    Try
      DocProperties.Save()
      MsgBox(ex.Message)
    End Try
    Try
      DocPropertySets.Close()
      MsgBox(ex.Message)
    End Try
    PropertyKey = Nothing
    PropertyValue = Nothing
    DocName = Nothing
    DocPath = Nothing
    DocProperties = Nothing
    DocPropertySets = Nothing
    myList = Nothing
    Try
      GC.Collect()
      MsgBox(ex.Message)
    End Try
    Return True
  End Function
Posted by: lu on
Post date: 9/26/2010 10:32:23 AM
RE: Custom Properties lock problem
You've got a object somewhere that is still referencing something in the API. Without looking at the whole program, there is really no way for us to know what's going on. Point is, you've got to free up every object you touch.
Posted by: Jason Newell
Post date: 9/26/2010 4:57:02 PM
Hello Luon,
Try this:
Imports System.Runtime.InteropServices
DocName = Nothing
DocPath = Nothing
myList = Nothing
If Not (DocProperties Is Nothing) Then
   Marshal.ReleaseComObject(DocProperties)
End If
If Not (DocPropertySets Is Nothing) Then
   Marshal.ReleaseComObject(DocPropertySets)
End If
GC.Collect()
GC.WaitForPendingFinalizers()
GC.Collect()
See http://www.jasonnewell.net/Forums/tabid/55/forumid/1/tpage/1/view/topic/postid/4240/Default.aspx#424...
The GC needs to be called twice in order to get the finalizers called -
the first time: it simply makes a list of what is to be finalized,
the second time: it actually the finalizing.
Only then will the object do it automatic ReleaseComObject.
I hope, this help
Peter
Posted by: Peter Caderas
Post date: 9/26/2010 8:33:56 PM
Hi All,
Funny result
There was no change with
GC.Collect()
GC.Collect()
The problem section was
        Try
          MsgBox(ex.Message)
        End Try
      End If
    Next
Even there was no property to delete file remained locked. (I think the problem was .Name property )
working function
      Try
        MsgBox(ex.Message)
      End Try
    Next
    Try
      MsgBox(ex.Message)
    End Try
    Try
      MsgBox(ex.Message)
    End Try
    DocName = Nothing
    DocPath = Nothing
    myList = Nothing
    End If
    End If
    Try
      GC.Collect()
      GC.Collect()
      MsgBox(ex.Message)
    End Try
    Return True
  End Function
Funny is the method .Add also update property if this property exist
Posted by: lu on
Post date: 9/26/2010 10:04:19 PM
