Customizing File Properties window
Hi, I'm creating an Addin that programmatically fills some properties of the file, loading those info from another system.
Is it possible to disable some fields of File Properties Window? For example, I would like to make the fields "Title" and "Subject" read only. I don't want to allow the user to change those properties that are programmatically assigned.
Posted by: Diogo Mafra
Post date: 4/22/2011 6:39:24 AM
