Cut or Extrude in the face selected
Olá boa tarde!
Por gentileza, alguém saberia me dizer como posso criar um “cut ou extrude” a partir da face selecionada?
Hello good afternoon!
Please someone tell me how can I create a "cut or Extrud" from the selected face?
Grateful
Edson Jesus
Posted by: Edson Silva de Jesus
Post date: 6/22/2010 10:50:57 AM
RE: Cut or Extrude in the face selected
You must have a Profile and make an ExtrudedCutouts in Model of the Part
so like this:
Dim objExtCut As SolidEdgePart.ExtrudedCutout
objDoc = objApp.ActiveDocument 'is a opened Part
Dim objSelSet As SolidEdgeFramework.SelectSet = objDoc.SelectSet
Dim objMod As SolidEdgePart.Model = objDoc.Models.Item(1)
Dim objProfileSet As SolidEdgePart.ProfileSet = objDoc.ProfileSets.Add
Dim objProfile As SolidEdgePart.Profile = objProfileSet.Profiles.Add(objSelSet.Item(1))
'ex. create a Circle
objProfile.Circles2d.AddByCenterRadius(0, 0, 0.015)
' Check if the Profile is closed
objProfile.End(SolidEdgePart.ProfileValidationType.igProfileClosed)
'make an ExtrudedCutout
objExtCut = objMod.ExtrudedCutouts.AddFinite(objProfile, SolidEdgePart.FeaturePropertyConstants.igLeft, SolidEdgePart.FeaturePropertyConstants.igRight, 0.01)
objProfile.Visible = False
Posted by: JR
Post date: 6/23/2010 1:29:11 AM
Thanks JR, functioned satisfactorily.
To select a face part, would have to create a reference plane?
Post date: 6/23/2010 2:28:55 AM
no,you need a new Profile, like this:
Dim numProf As Integer
Dim allProf(1) As Object 'SolidEdgePart.Profile
Dim objFeature As SolidEdgePart.ExtrudedProtrusion = objMod.Features.Item(1)
objFeature.GetProfiles(numProf, allProf)
Dim objProfile As SolidEdgePart.Profile = objProfileSet.Profiles.Add(allProf(0).Plane)
Posted by: JR
Post date: 6/23/2010 3:15:18 AM
JR thanks for the feedback.
Edson Jesus
Post date: 6/23/2010 5:11:01 AM
