CuttingPlanes property not getting executed...?
Hi All,
i have placed right view through modellink object. now i want to add cutting plane line and then place section view
to the left side. But it is not getting executed. i m trying following:
Dim oSEApp As SolidEdgeFramework.Application
Dim oSEDft As SolidEdgeDraft.DraftDocument
Dim ObjModelLink As SolidEdgeDraft.ModelLink
Dim Objviews As SolidEdgeDraft.DrawingViews
Dim Objview1 As SolidEdgeDraft.DrawingView
Dim ObjSheet As SolidEdgeDraft.Sheet
Dim Objcut As Object
oSEApp = GetObject(, "SolidEdge.Application")
oSEApp.Visible = True
oSEDft = oSEApp.Documents.Add("Solidedge.DraftDocument")
ObjSheet = oSEDft.ActiveSheet
Objviews = ObjSheet.DrawingViews
ObjModelLink = oSEDft.ModelLinks.Add(path)
Objview1 = Objviews.AddAssemblyView(ObjModelLink, SolidEdgeDraft.ViewOrientationConstants.igRightView, 1.5, 0.41, 0.26, SolidEdgeDraft.AssemblyDrawingViewTypeConstants.seAssemblySimplifiedView, "")
Objview1.ModelMembers.Item(1).ShowHiddenEdges = False
Objview1.ModelMembers.Item(1).ShowEdgesHiddenByOtherParts = False
Objcut = ObjSheet.CuttingPlanes....here it is getting failed.
Any suggetions? Thanks in advance
Prasad Pawar
(Design Automation Engg.)
Posted by: Prasad Pawar
Post date: 10/14/2007 11:44:22 PM
RE: CuttingPlanes property not getting executed...?
Hey all,
still waiting for the reply...
Post date: 10/17/2007 5:46:42 PM
Prasad,
Can you upload a .zip'd .dft that has a drawing view with cutting planes? I tried creating one myself but couldn't get the cutting plane command to work for some reason. Remeber, I'm not a SE user!
Posted by: Jason Newell
Post date: 10/17/2007 6:10:58 PM
jason
u didnt get wht i am trying to say.... u can take new draft file also. i am placing the view from the code above. now on the view that has just placed , i want to add cuttingplane and place section on the left side of that
Post date: 10/17/2007 9:12:31 PM
Hi All,
In Prgramming with SE section there are command constants given (CuttingPlaneCommandConstants Constant Set). But i am not finding any reference how to make use of it to draw cutting plane and section view.
Anybody have any idea?
Post date: 10/28/2007 5:57:56 PM
