DFT - before save event runs more than once
Hi guys,
SE 2019, draft mode.
I'm opening first document, click on "Save" button - the BeforeDocumentSave event runs once. I'm closing document, opening another one - The BeforeDocumentSave event runs twice... For third one - three times etc....
Bug or what's going on?
Re: DFT - before save event runs more than once
Hi @OggiePL,
I don't think this is a problem of Solid Edge. I assume your  program registers the event again after it fires.
So this builds a loop and every time the handler routine is called one more time.
JB
SE 2019, VS2017
Can't find a reason.
Events are being connected in the standadrd way:
        private SolidEdgeFramework.Application _application;
        private IConnectionPoint _connectionPoint;
        private int _cookie;
        public MyEdgeBarControl()
            InitializeComponent();
        private void MyEdgeBarControl_Load(object sender, EventArgs e)
            // Trick to use the default system font.
            this.Font = SystemFonts.MessageBoxFont;
            _application = (SolidEdgeFramework.Application)Marshal.GetActiveObject("SolidEdge.Application");
            ConnectEvents();
        private void ConnectEvents()
            // Get the event GUID.
            var typeGuid = typeof(SolidEdgeFramework.ISEApplicationEvents).GUID;
            // Get a reference to the IConnectionPointContainer.
            IConnectionPointContainer container = (IConnectionPointContainer)_application;
            // Lookup the IConnectionPoint.
            container.FindConnectionPoint(ref typeGuid, out _connectionPoint);
            // Advise the sink.
            _connectionPoint.Advise(this, out _cookie);
