DashStyle.SetDashGap returns NotImplemented error
The SetDashGap method of DashStyle object throws a "not implemented exception".
Here is a code snippet that will demonstrate.
        Dim DashStyle As SolidEdgeFramework.DashStyle = SEDft.DashStyles.item("Dot")
        Dim DashGapCount As Long = DashStyle.DashGapCount
        Dim DashGap(DashGapCount - 1) As Double
        DashStyle.GetDashGap(DashGapCount, DashGap)
        For ii = 0 To UBound(DashGap)
            DashGap(ii) = 2 * DashGap(ii)
        Next
        Try
            DashStyle.SetDashGap(DashGapCount, DashGap)
        Catch ex As Exception
            Console.WriteLine(ex.ToString)
        End Try
Any help will be greatly appreciated.
Gerald
Re: DashStyle.SetDashGap returns NotImplemented error
Solution: The method is only available for new DashStyles.
regards Gerald
