Defining Mate in Assembly documnet
HI ALL
i want to define mate of parts in to assembly document.for do this which class and properties are to be use(API) in VB.net please help me...
Posted by: Yogesh Shinde
Post date: 5/7/2012 12:16:47 AM
Re: Defining Mate in Assembly documnet
The AssemblyDocument has a Relations3d property which holds all assembly relations. This collection has a method to create a Mate relation:
objRelations.AddPlanar()
You might check the API help for an example. If the used faces/planes are in a suboccurrence, you have to create a reference to them and then pass the reference to the AddPlanar method.
Posted by: Martin Bernhard
Post date: 5/7/2012 4:04:25 PM
