DeleteFaces.Add()
Does somebody knows, how I can add a new feature "DeleteFace".
The Model-object has a collection of "DeleteFaces", where I can add a new object. The "Add" method has one parameter "FaceSetToDelete As Object". How must I prepare the faces in this object?
Has somebody an example for me?
Erich
Posted by: Erich Hohloch
Post date: 4/25/2013 6:17:11 AM
DeleteFaces.Add()
I don't have an example, but from the description, I would try to pass either an array of faces or a FaceCollection object.
Posted by: Martin Bernhard
Post date: 4/25/2013 9:27:19 AM
DeleteFaces.Add()
Unfortunately not.
First I tried with an array (VBA):
[code]
Public Sub DeleteFacesByArray()
Dim oSeApp As SolidEdgeFramework.Application
Dim oPartDoc As SolidEdgePart.PartDocument
Dim oModel As SolidEdgePart.Model
Dim oDeletedFaces As SolidEdgePart.DeleteFaces
Dim oBody As SolidEdgeGeometry.Body
Dim oShell As SolidEdgeGeometry.Shell
Dim oFace As SolidEdgeGeometry.Face
Dim iCountFaces As Integer
Dim i As Integer
Dim oFaces2Delete() As SolidEdgeGeometry.Face
Set oSeApp = GetObject(, "SolidEdge.Application")
Set oPartDoc = oSeApp.ActiveDocument
For Each oModel In oPartDoc.Models
Set oDeletedFaces = oModel.DeleteFaces
Set oBody = oModel.Body
For Each oShell In oBody.Shells
If oShell.IsVoid Then
iCountFaces = oShell.Faces.Count
ReDim oFaces2Delete(iCountFaces - 1)
For i = 0 To iCountFaces - 1
Set oFace = oShell.Faces(i)
Set oFaces2Delete(i) = oFace
Next i
oDeletedFaces.Add (oFaces2Delete) ' < --Compiler gets an error: Incompatible Types '
End If
Next oShell
Next oModel
End Sub
[/code]
Next Try with SolidEdgeGeometry.Faces (-Collection)
[code]
Public Sub DeleteInnerFaces()
Dim oFacesToDelete As SolidEdgeGeometry.Faces
Set oFacesToDelete = oShell.Faces
Call oDeletedFaces.AddNoHeal(oFacesToDelete) ' <-- Method fails '
End If
Next oShell
Next oModel
End Sub
[/code]
Any Idea?
Erich
Post date: 4/26/2013 1:40:52 AM
