Deploy Solid edge Addin in different machine
I developped lately an addin for solid edge ready for use.
I want to know if there is a way  to control its acces by number of user (like floating license ).only a specific  number of user can acces to it in the same time.
Amani
Re: Deploy Solid edge Addin in different machine
I have zero experience on this topic but I would lean toward an off the shelf solution. Solid Edge uses a product formerly called FlexLM.
http://www.flexerasoftware.com/producer
Jason Newell
Applications Architect
www.jasonnewell.net
