Dertermine DocumentType for OnFileSaveAsUI
I've the follwoing problem. I want to save files in PDM System if the OnFileSaveAsUI event occours. For this I've to determine the DocumentType (or extension) of the file. In normal case I use SolidEdgeApplication.ActiveDocument to dertermine this.
But now I want it work for "Part Create In Place" in an assembly.
The OnCreateInPlacePartUI does not work proper for me so far. If I return a file name there still comes a save as dialog afterwards. So I decide to do the work at the end of the (user interactive) process when the newly created file 'll be saved.
Any Ideas?
