Detect a mirrored part or assembly
In VB.Net, how can I know if a part or an assembly is a mirrored part (assembly)?
Thank you in advance for your cooperation.
16 REPLIES 16
Re: Detect a mirrored part or assembly
Hi @JonaMeha
I haven't found a direct way to achieve this, at least for ST9
What I do for PARTS is the next:
  • I look in the Part.Models collection for each Model in the part.
  • then i check if this model has CopiedParts.
  • If it has copiedParts and the copiedPart.Plane property is not null, then the part is a mirrored one.
For assemblies, I haven't found a solution, what I do is checking the asm name looking for "_mir", but that a file contains "_mir" in his name not necessarily implies that file to be a mirrored one.
Hope it helps.
Héctor Pelayo Izquierdo
Engineering Department, JAE Ingeniería y Desarrollos, S.L.
Solid Edge ST9 MP5 | NX 9
Development: VB.NET
Here is a solution for both Part and Assembly types:
    Private Function isAssemblyMirrored(doc As SolidEdgeAssembly.AssemblyDocument)
        Try
            Dim objAssemblyCopies As SolidEdgeAssembly.AssemblyCopies = doc.AssemblyCopies
            Dim objAssemblyCopy As SolidEdgeAssembly.AssemblyCopy = objAssemblyCopies.Item(1)
            Return (objAssemblyCopy.AssemblyCopyType = SolidEdgeAssembly.AssemblyCopyTypeConstants.seAssemblyCopyTypeMirror)
        Catch ex As Exception
        End Try
        Return False
    End Function
    Private Function isPartMirrored(doc As SolidEdgePart.PartDocument)
        Dim ebf As SolidEdgePart.EdgebarFeatures = doc.DesignEdgebarFeatures
        For Each obj As Object In ebf
            Try
                Dim feat As CopiedPart = obj
                Return Not IsNothing(feat.Plane)
            End Try
        Next
        Return False
    End Function
________[Oo\____/oO]________
The truth is .... I am Dutch
C# - VS Ex 2015 - Solid Edge ST10 MP3 - TC11.4
Key-User, IT-student, no admin rights
Hey Hector, Hey JanWillem,
Thank you so much for your all help but none of what you are proposing works.
I once thought it was due to the planes of symmetry I used for my tests, because I used standard reference planes (top, right or front) but in any event...I can't get any result.
Thank you again.
Which one doesn't work? In my case, both functions work.
Can you share a part file that doesn't work for you?
Please find enclosed a compressed file containing the main assembly file ("Asm2.asm") and all its sub-asm and parts.
See no technical consistency in it, it is only used for tests.
More precisely, for processing (collection of description, quantity, etc...) of assemblies and parts in various situations (copied, copy, mirrored, mirror, copy of mirror, mirror of copy, etc...).
Hoping you can do something with it.
Thanks a lot,
I've modified my code to test on your assembly:
    Private Function checkMirrored(doc As SolidEdgeAssembly.Occurrence)
        If doc.Subassembly Then
            Return isAssemblyMirrored(doc)
        Else
            Return isPartMirrored(doc)
        End If
    End Function
    Private Function isAssemblyMirrored(doc As SolidEdgeAssembly.Occurrence)
        Dim assyDoc As SolidEdgeAssembly.AssemblyDocument = doc.OccurrenceDocument
        Try
            Dim objAssemblyCopies As SolidEdgeAssembly.AssemblyCopies = assyDoc.AssemblyCopies
            If (objAssemblyCopy.AssemblyCopyType = SolidEdgeAssembly.AssemblyCopyTypeConstants.seAssemblyCopyTypeMirror) Then
                Return True
            End If
        End Try
        Return False
    End Function
    Private Function isPartMirrored(doc As SolidEdgeAssembly.Occurrence)
        Dim partDoc As SolidEdgePart.PartDocument = doc.OccurrenceDocument
        Dim ebf As SolidEdgePart.EdgebarFeatures = partDoc.DesignEdgebarFeatures
            Try
            End Try
        Next
        Return False
    End Function
As a test, I ran this code:
Dim Occurences As SolidEdgeAssembly.Occurrences
        Occurences = seADocument.Occurrences
        Dim message As String
        message = "Testing" + vbNewLine
        For index = 1 To Occurences.Count
            Dim doc As SolidEdgeAssembly.Occurrence = Occurences.Item(index)
            message += doc.Name.ToString
            message += "  -  "
            message += checkMirrored(doc).ToString
            message += vbNewLine
        Next
        MsgBox(message)
I believe the result is what you're looking for (see image attached)
        Else
        End If
    End Function
        Try
                Return True
            End If
        End Try
        Return False
    End Function
            Try
            End Try
        Next
        Return False
    End Function
            message += "  -  "
        Next
        MsgBox(message)
        Else
        End If
    End Function
        Try
                Return True
            End If
        End Try
        Return False
    End Function
            Try
            End Try
        Next
        Return False
    End Function
            message += "  -  "
        Next
        MsgBox(message)
        Else
        End If
    End Function
        Try
                Return True
            End If
        End Try
        Return False
    End Function
            Try
            End Try
        Next
        Return False
    End Function
  message += "  -  "
Next
MsgBox(message)
