Dimension in Draft
Hi all....
I have a problem ..
There is a problem with the output dimension
As shown in the attached image where the view is wrong with dimensionsAsshown inthe attachedimagewherethe viewis wrongwithdimensions
Dimensioningof the viewthat matches thewaytothe lineis missing?
The sourceundera program thatautomaticallyprints thedrawing'ssource.
Seemeandhelp would be appreciated
Solid edge st2
vb6.0
  strParFile = "C:\Users\yheom\Desktop\????11.dft"
 Set objApp1 = GetObject(, "SolidEdge.Application")
 Set objDftDoc = objApp1.Documents.Add("SolidEdge.DraftDocument", strParFile)
 Set objSections = objDftDoc.Sections
 For i = 1 To objSections.Count
  Set objSection = objSections.Item(i)
  Set objSectionSheets = objSection.Sheets
 Next i
 'For i = 1 To objSectionSheets.Count
  'Set objSheet1 = objSectionSheets.Item(i)
 'Next i
 Set objSection = objSections.WorkingSection
 'Set objSection = objSections.BackgroundSection
 Set objSheets = objDftDoc.Sheets
 ' strParFile = "C:\Users\yheom\Desktop\????11.dft"
 'objSheet1 = objSheets.AddSheet("?????", SheetSectionTypeConstants.igWorkingSection)
 Set objSheet1 = objDftDoc.ActiveSheet
  objSheet1.Visible = True
 'Set objSheet1 = objDftDoc.ActiveSheet
  objSheet1.SheetSetup.SetDefaultDrawingViewScale 1, 20
 objSheet1.SheetSetup.SetScale 1, 20
 objSheet1.SheetSetup.GetScale px, py
 objSheet1.Activate
 'Call objSheet1.SheetSetup.SetDefaultDrawingViewScale(0.5, 0.5)
 Set sheetwindow1 = objApp1.ActiveWindow
 px = objSheet1.SheetSetup.SheetHeight * 1000
 py = objSheet1.SheetSetup.SheetWidth * 1000
 MsgBox px & "," & py
 Set objDrawingObjects = objSheet1.DrawingObjects
   Set objDrawingViews = objSheet1.DrawingViews
  'objDrawingViews.Align
  cnt = objDrawingViews.Count
  For i = 1 To cnt
   Call objDrawingViews.Item(i).Update
     Set objDrawingView = objDrawingViews.Item(i)
     'objDrawingView.SetOrigin dx, dy
    Call objDrawingView.Range(xMin, xMax, yMin, yMax)
    objDrawingView.ScaleDimensionsAndAnnotations = True
    'objDrawingView.SetOrigin 1, 2
    For m = 1 To objDrawingView.DVLines2d.Count
        objDrawingView.DVLines2d.Item(m).ModelMember.ShowHiddenEdges = False
        objDrawingView.DVLines2d.Item(m).ModelMember.ShowEdgesHiddenByOtherParts = False
        objDrawingView.DVLines2d.Item(m).ModelMember.ShowTangentEdges = False
    Next m
   ' For m = 1 To objDrawingView.DVCircles2d.Count
   '     objDrawingView.DVCircles2d.Item(m).ModelMember.ShowHiddenEdges = False
   '     objDrawingView.DVCircles2d.Item(m).ModelMember.ShowEdgesHiddenByOtherParts = False
   '     objDrawingView.DVCircles2d.Item(m).ModelMember.ShowTangentEdges = False
   ' Next m
  '  For m = 1 To objDrawingView.DVArcs2d.Count
  '      objDrawingView.DVArcs2d.Item(m).ModelMember.ShowHiddenEdges = False
  '      objDrawingView.DVArcs2d.Item(m).ModelMember.ShowEdgesHiddenByOtherParts = False
  '      objDrawingView.DVArcs2d.Item(m).ModelMember.ShowTangentEdges = False
  '  Next m
    Call objDrawingView.Update
   Next i
  For i = 1 To cnt
    objDftDoc.ActiveSheet.Activate
    Set sedims = objDftDoc.ActiveSheet.Dimensions
    ReDim dblX1(objDrawingView.DVLines2d.Count)
    ReDim dblY1(objDrawingView.DVLines2d.Count)
    Set line = objDrawingView.DVLines2d.Item(m)
    objDrawingView.RetrieveDimensions True
    If line.EdgeType = seModelEdgeType Then
     Call line.GetStartPoint(dblX1(m), dblY1(m))
        If m > 1 Then
         If (line.Length) * 1000 > 20 Then
            dx = (dblX1(m) - dblX1(m - 1)) * (dblX1(m) - dblX1(m - 1))
            dy = (dblY1(m) - dblY1(m - 1)) * (dblY1(m) * -dblY1(m - 1))
            dd = dx + dy
            dd = Abs(dd)
            dd = Sqr(dd)
            dd = dd * 1000
            If dd > 20 Then
             'If line.Length > 30 Then
             Set SEdim = objSheet1.Dimensions.AddLength(line)
             'End If
            End If
         End If
        ElseIf m = 1 Then
             SEdim.BreakPosition = igDimBreakCenter
             SEdim.BreakDistance = 0.5
        End If
    End If
  Next m
     ReDim dblX2(objDrawingView.DVCircles2d.Count)
     ReDim dblY2(objDrawingView.DVCircles2d.Count)
     Set line2 = objDrawingView.DVCircles2d.Item(m)
   If line2.EdgeType = seModelEdgeType Then
     Call line2.GetCenterPoint(dblX2(m), dblY2(m))
     If m = 1 Then
      Set SEdim = sedims.AddCircularDiameter(line2)
     ElseIf m > 1 Then
      If (line2.Diameter) * 1000 > 15 Then
        dx = (dblX2(m) - dblX2(m - 1)) * (dblX2(m) - dblX2(m - 1))
        dy = (dblY2(m) - dblY2(m - 1)) * (dblY2(m) * -dblY2(m - 1))
        dd = dx + dy
        dd = Abs(dd)
        dd = Sqr(dd)
        dd = dd * 1000
        If dd > 20 Then
        End If
      End If
     End If
   End If
  Next m
     ReDim dblX3(objDrawingView.DVArcs2d.Count)
     ReDim dblY3(objDrawingView.DVArcs2d.Count)
     Set arc1 = objDrawingView.DVArcs2d.Item(m)
   If arc1.EdgeType = seModelEdgeType Then
     Call arc1.GetCenterPoint(dblX3(m), dblY3(m))
     If m = 1 Then
      Set SEdim = sedims.AddLength(arc1)
     ElseIf m > 1 Then
      If (arc1.Radius) * 1000 > 30 Then
        dx = (dblX3(m) - dblX3(m - 1)) * (dblX3(m) - dblX3(m - 1))
        dy = (dblY3(m) - dblY3(m - 1)) * (dblY3(m) * -dblY3(m - 1))
        dd = dx + dy
        dd = Abs(dd)
        dd = Sqr(dd)
        dd = dd * 1000
        If dd > 30 Then
          Set ObjDimStyle = SEdim.Style
        End If
      End If
     End If
    End If
  Next m
 Next i
Posted by: eom younghwee
Post date: 6/28/2011 7:04:28 PM
RE: Dimension in Draft
try this
Set SEdim = objSheet1.Dimensions.AddLength(line.reference)
eric
Posted by: BONNAUDET eric
Post date: 7/6/2011 11:52:13 PM
Thank you very much.
I saw to try was successful.
One API is really thanks so troubled.
Post date: 7/7/2011 1:42:35 PM
