Dimension positioning in Draft File
Hello, Everyone!
I am trying to do draft automation. As of now I have completed
Scaling the drawing view as per Increase in model
Scaling Dimensions to suit the scaled view
Check View Overlapping if yes then maintain views at fix distance
But when I am performing scaling operation Dimensions are getting shifted.
I tried to specify the track distance to all dimension but still some dimension are getting overlapped in views or on other dimensions.
Is there any way i can position the dimension?
