Disable Solidedge while addins command runs
How to disable Solidedge window, when a addin command is running.
Jaya
Posted by: jaya priyan
Post date: 1/28/2008 9:39:18 PM
RE: Disable Solidedge while addins command runs
Hi Jaya,
use Application.Interactive = false;
Cheers
Calum
Posted by: Calum McLellan
Post date: 1/28/2008 9:48:52 PM
Thanks calum. Your snippet did the trick.
Post date: 1/28/2008 10:11:03 PM
