Disable or hide the form close button
It is possible to hide or disable the "X" at the top right of a windows form?
I have an addin that pops up a form. I don't want the user to be able to close the form without completing the form.
I tried:
e.Cancel = True
in the forms closing procedure, but it doesn't prevent the form from closing.
Thanks in advance,
Mike
Posted by: Michael Frayser
Post date: 11/9/2005 10:05:41 AM
RE: Disable or hide the form close button
Mike,
Try this.
Posted by: Jason Newell
Post date: 11/9/2005 10:11:02 AM
Posted By Jason Newell on 11/9/2005 4:11:02 PM
Mike,
Try this.
Okay, that sorta worked. Now how do I hide the close button at the bottom left of the form?
Post date: 11/10/2005 12:09:49 AM
Sorry Mike, I don't understand what you're asking on this one . Can you be a little more specific?
Post date: 11/10/2005 5:51:10 AM
I want to hide or disable the Close form button (red "X" in XP) at the top right of the titlebar of a windows form. I have found a work-around, but it would be easier to just hide the button.
Post date: 11/10/2005 7:21:04 AM
What about Form1.ControlBox = false?
Post date: 11/10/2005 10:38:07 AM
Posted By Jason Newell on 11/10/2005 4:38:07 PM
Duh! That was easy. I think I even used that in a VB class I took a couple of years ago. Thanks for the reminder!
Post date: 11/11/2005 12:15:25 AM
