Displaying and showing background tabs
Hi all
How do you hide the background sheet tabs without using    Objse.StartCommand (10211)
'Set BackSheetsUpdateFile = ObjdraftUpdateFile.Sections.BackgroundSection.Sheets'   shows the background ..... but how do you hide them again?
Had a hunt and found the command
Objse.ActiveDocument.SheetWindow.DisplayBackgroundSheetTabs = False       doesn't seem to work     Err msg object doesn't support or method
any ideas?
Oh while i remember
        ObjdraftTemplate.SelectSet.AddAll   'select all infomation on sheet
        ObjdraftTemplate.SelectSet.Copy     ' Copy to Clipboard
Is there a way to copy to clipboard without having the sheet in the active window. because the AddAll command works no matter weather the sheet is active or not and when you fire the Copy command and the sheet isn't active the clipboard get nothing?
Cheers Snow
Posted by: Snow Mackenzie
Post date: 9/10/2008 11:25:31 PM
RE: Displaying and showing background tabs
This does work for me in VB6 to not show the Background Sheet tabs:
'If Background Sheets are visible, turn off
If objApp.ActiveWindow.DisplayBackgroundSheetTabs = True Then
objApp.ActiveWindow.DisplayBackgroundSheetTabs = False
End If
- Bill
Posted by: Bill Ledbetter
Post date: 9/12/2008 3:27:56 AM
