Document Units Precision
Whereas the following works and changes the unit to 'ft-in':
objDoc.UnitsOfMeasure.Item(UnitTypeConstants.igUnitDistance).Units = SolidEdgeConstants.UnitOfMeasureLengthReadoutConstants.seLengthFootInch
the follownig line of code does not change the precision field in the Document Properties - Units tab - Precision setting to 1/16 th:
objDoc.UnitsOfMeasure.Item(UnitTypeConstants.igUnitDistance).Precision = SolidEdgeConstants.PrecisionConstants.igPrecisionSixteenths
Any clues on what might be wrong with this or how to get this working ?
Thanks.
Tushar Suradkar
