Documents.open how to prevent prompts?
When i call Documents.open on a psm, I get a prompt saying "This file contains links to the assembly...." is there any way to prevent these messages from appearing and just forcing the application to load the psm.. I dont care about the assembly.
Currently, my only thoughts are to create another thread that is monitoring for these dialogs and clicking No automatically.
Posted by: maury terneus
Post date: 6/22/2013 3:06:44 PM
You may set the Solid Edge application object property DisplayAlerts to false.
Posted by: Wolfgang Kunert
Post date: 6/23/2013 12:33:20 AM
You can also try Application.Interactive = False. Just be sure to turn it back on. The majority of the APIs honor DisplayAlerts although I have seen some that don't.
Posted by: Jason Newell
Post date: 6/23/2013 8:40:24 AM
thanks guys!
Post date: 6/23/2013 1:51:42 PM
