Download File from Teamcenter
Bom dia a todos!
Estou na luta para fazer downloads de arquivos do Teamcenter através do Cache Assistant.
Application Button >> Manage >> Cache Assistant >> Download >> Select >> Open.
Desenvolvi o seguinte código em VB.net:
Dim oSEApp As SolidEdgeFramework.Application
Dim oSETc As SolidEdgeFramework.SolidEdgeTCE
oSEApp = GetObject(, "SolidEdge.Application")
oSETc = oSEApp.SolidEdgeTCE
Dim objItem AsString
Dim objRev AsString
Dim Ret AsObject
Dim objDataset AsString
Dim N AsInteger
Dim strPath AsString
objItem = "CL19-00002"
objRev = "A"
objDataset = objItem & "/" & objRev
oSETc.GetListOfFilesFromTeamcenterServer(objItem, objRev, Ret, N)
        oSETc.DownladDocumentsFromServerWithOptions(objItem, objRev, objItem & "/" & objRev, "", "", False, True, 2, Ret)
Entretanto, não consigo realizar o Download dos documentos relacionados ao item CL19-00002.
Em um download reazildado pelos comandos próprios do Solid Edge:
O arquivo selecionado vai para: C:\Documents and Settings\User\Application Data\Unigraphics Solutions\Solid Edge\SEEC\http_server_7000_tc\user\Default.
Como fazer com que o código se comporte da mesma forma?
Grato
Edson Jesus
Good morning everyone!
I'm in the struggle to download files from Teamcenter through the Cache Assistant.
Developed the following code in VB.net:
Dim objRev AsString
Dim Ret AsObject
Dim N AsInteger
objRev = "A"
However, I can not perform the download of documents related to the item
 CL19-00002.
In a download reazildado by the commands of their own Solid Edge:
The selected file is going to: C:\Documents and Settings\User\Application Data\Unigraphics Solutions\Solid Edge\SEEC\http_server_7000_tc\user\Default.
How to make the code behave the same way?
Grateful
Edson Jesus
Posted by: Edson Silva de Jesus
Post date: 6/23/2010 2:56:59 AM
RE: Download File from Teamcenter
Bonjour,
I also tried to make "DownladDocumentsFromServerWithOptions"  works ... unsuccessfully.
Did you finally managed to make it work ?
Thanks in advance
Ludovic
Posted by: Ludovic BOUILLON
Post date: 8/3/2010 5:29:05 AM
Sub DownladDocumentsFromServerWithOptions(bstrItemId As String, bstrItemRev As String, bstrDataSetFileName As String, bstrRevisionRule As String, bstrVariantRule As String, vbReadOnly As Boolean, vbAllLevel As Boolean, dwDownloadOption As , [pvarListOfFiles() As Variant])
bstrDataSetFileName must be the same name as it was saved in :
C:\Documents and Settings\User\Application Data\Unigraphics Solutions\Solid Edge\SEEC\http_server_7000_tc\user\Default\
ex :
- open a TCX file in SolidEdge
this file is saved in directory cache C:\Documents and Settings\User\Application Data\Unigraphics Solutions\Solid Edge\SEEC\http_server_7000_tc\user\Default\
- bstrDataSetFileName = name of the file in the cache directory
- delete this file
- try DownladDocumentsFromServerWithOptions with the good bstrDataSetFileName
-> the file is created in C:\Documents and Settings\User\Application Data\Unigraphics Solutions\Solid Edge\SEEC\http_server_7000_tc\user\Default\
Posted by: inoujk inoujk
Post date: 3/29/2011 9:33:01 PM
Re: Download File from Teamcenter
use CheckOutDocumentsFromTeamCenterServer("LB31.0000.60-20.02.00.00", "00", true);
insteed
DownladDocumentsFromServerWithOptions(...)
It's work in C# SE St4
Posted by: Georgi Georgiev
Post date: 8/30/2012 1:30:36 AM
