Draft Document Parts List's List Properties
Is there anyway for me, in programming, to change the Saved Settings on the General Tab in the properties of a Parts List... Someone please give me some information on this... Thanks...
Posted by: Mike Anderson
Post date: 6/19/2006 7:06:25 AM
RE: Draft Document Parts List's List Properties
Mike,
The only thing that I see is a write only property "SavedSettings" in the PartsList object. With this property, you can do objPartsList.SavedSettings = "ANSI" for instance. I do not see a way to set the individual properties in the dialog window.
Hope this helps.
Posted by: Jason Newell
Post date: 6/19/2006 7:32:48 AM
Jason, thanks alot. This really helped me out. I needed to be able to change this to a custom setting. I used partslists.savedsettings = "mysetting" and then partslists.update for anyone who needed to know... Thanks alot Jason...
Post date: 6/19/2006 11:00:23 PM
I'm having trouble finding information on how to by pass the Drawing View Tracker in programming. All I can find is objDoc.DrawingViewEvents but I just don't know how to use this... Can someone point me in the direction where I can learn about some of this...?
Post date: 6/20/2006 1:12:10 AM
I dug a little deeper and found the boolean ScreenUpdating. This does it...
Post date: 6/20/2006 5:38:35 AM
