Draft Document to move
Then I have a question.
Have to go to the Draft document of the document that is currently Active
Is there a source?
Re: Draft Document to move
There is not a "back link" to the draft from an Assembly or Part. Keep in mind that there may be 0 < N links from a model to a draft. The best option off the top of my head is to use the RevisionManager API to find the draft(s). See Application.FindWhereUsed(). I would imagine there are some examples here on the forums if you search for "FindWhereUsed".
Jason Newell
Solutions Architect
www.jasonnewell.net
Jason ...
Thank you for always. Let's take advantage of the Find Where Used.
