Draft - Drag document and drop inside of sheet
Hello developers, I have a question about drag a part/sheet metal/assembly document and drop inside a sheet Draft document.
I have a string fullFileName. How do that? With events? Does anyone have any sample code?
Kabir Costa
Industrial Designer
kabircosta@gmail.com
Re: Draft - Drag document and drop inside of sheet
I made a little example. Just copy-paste the code in a VB.Net project.
It is a form with a textbox with a .par filename in it,
You can drag from the textbox and drop into a sheet in an open DFT file in Solid Edge. (it places a view)
The same thing can be done with an open ASM. the part will be placed.
The code is this:
Public Class Form1
    Dim isMouseDown As Boolean = False
    Private Sub TextBox1_MouseDown(sender As Object, e As MouseEventArgs) Handles TextBox1.MouseDown
        isMouseDown = True
    End Sub
    Private Sub TextBox1_MouseMove(sender As Object, e As MouseEventArgs) Handles TextBox1.MouseMove
        If isMouseDown Then
            Dim files(0) As String
            files(0) = TextBox1.Text
            Dim data As DataObject = New DataObject(DataFormats.FileDrop, files)
            DoDragDrop(data, DragDropEffects.Copy)
        End If
    End Sub
    Private Sub TextBox1_MouseUp(sender As Object, e As MouseEventArgs) Handles TextBox1.MouseUp
        isMouseDown = False
    End Sub
End Class
Julian Guillo
Pixel Sistemas SL
Spain
