Draft File
Hi All,
I have a draft file in Solid Edge. I am writing an API in VB.NET to store all existing blocks of a file in some folder at local system or at network.
anybody having any idea please give me some hint, so that I can proceed.
Posted by: Nudrat Hassan
Post date: 4/8/2008 2:30:07 AM
RE: Draft File
Could you please reply with a .zip of a .dft that has blocks in it. I seem to be having trouble figuring out how to create blocks in Solid Edge :-o
Posted by: Jason Newell
Post date: 4/16/2008 8:47:02 PM
RE: Draft File
typical programmer
Posted by: Calum McLellan
Post date: 4/16/2008 10:10:44 PM
RE: Draft File
Dear Jason Newell,
actually I am able to draw blocks in Solid edge manually. even I am able to copy blocks from one draft to another draft file programmaticaly. but exactly its not copying, its simply showing in edge bar.
if u figure out something more, do let me know.
thanx for the reply.
Post date: 4/17/2008 12:18:23 AM
