Draft Variable table linked to .bas
Hi all
Does anyone have any example of how to link a .bas file to a variable table function?
all i get is errors
my .bas file is this simple (Just testing the waters and i know this can be done from the table it's self)
Public Sub GetSheetCount(ByRef SheetCount As Integer)
SheetCount = SheetCount + 100
End Sub
Basically pass a number in to it and add 100 to it , How do you link the argument and pass a number into it?
Cheers Snow
Posted by: Snow Mackenzie
Post date: 9/17/2008 1:16:53 PM
RE: Draft Variable table linked to .bas
Posted By Snow Mackenzie on 09/17/2008 6:16 PM
Hi all
all i get is errors
End Sub
Cheers Snow
Snow,
I believe you simply need to make it a Function rather than a Sub.  The following example works for me.
 Public Function MMtoM(MillimeterValue As Double) As Double MMtoM = MillimeterValue / 1000End Function'Returns a number converted from meters to millimetersPublic Function MtoMM(MeterValue As Double) As Double MtoMM = MeterValue * 1000End Function
Posted by: Jason Newell
Post date: 9/21/2008 7:37:39 PM
