Draft change corner block location
We've changed the standard location of the cornet in the bottom of the right side. We have to replace this corner with revision manager or copy and past the files to the project folder.
I want to do this with a macro ( VBA ) but I can't find the location of this corner in Solid edge Spy. I want to push a button which changes the location to the new location.
Kindly Regards,
Justin
