Drafting: How to set "Autoscale" when adding a view
HI,
when adding a view to a drawing, you must specify a Scale value.
But I have a list of files (assemblies and parts) with different dimensions.
I must create a drawing for every object (A3 format for axample).
But I need to set the scale of the view in a way that I'm sure the view fit inside the papersize.
IThere is a way to do this with API?
Something like "Autoscale" the Model to "fit" inside the view boundaries?
Thanks in advance for any info.
Best Regards
Massimo
Posted by: Massimo Magris
Post date: 6/2/2009 10:49:27 AM
RE: Drafting: How to set "Autoscale" when adding a view
You can place the view with default scale, and then adjust the view scale by your sheet size.
Posted by: assassin 007
Post date: 6/2/2009 5:41:24 PM
For example, you can get all view's range, and then, you will get the area of each view. You know the sheet area, so, you can caculate the view scale.
Post date: 6/2/2009 5:43:37 PM
