Drafting how to do rectangular selection via API?
how to select all entities inside a selection box (x,y,x1,y1)
via API?
Thanks, best regards
Massimo
Re: Drafting how to do rectangular selection via API?
Are you allowing end-user to select objects inside a reactangle or already have the known rectangle coordinates ?
Hi, already know the coordinates like
SelectWindow (x,y,x1,y1) 'lowerleft and upperright cornet
I can loop through all the textboxes to see if coordinate match, but it's time consuming.
There is way to "select" by region via API?
Massimo
