Drafting, how to replace title block
HI,
there is an example of how to replace the title block?
I need to process a list of old drawings and replace the old title block with a new one.Something like
Call ReplaceTitleBlock (DftFileName,NewTitleBlockFileName)
Thanks in advance for any info.
Best Regards
Massimo
Posted by: Massimo Magris
Post date: 6/14/2011 3:44:20 AM
RE: Drafting, how to replace title block
I'm at the launch event right now so I don't have code in front of me.The way we do this is, since our entire background sheet is all of the Titleblock:- Activate the corresponding background sheet.- Select all- Delete- Open file with new background- Select all- Copy- go back to first file.- Paste.This has worked well for us for a few years.Let me know if you want specifics.
Posted by: Carl Breving
Post date: 6/16/2011 8:17:40 AM
Hi Carl, thanks for the infos.
If you can post the code, can be useful for other also.
Thanks and regards.
Massimo
Post date: 6/30/2011 2:06:52 PM
