Drag and drop from parts library C#
Innovator
Innovator
I want to drag a part document from parts library and drop it inside a assembly document with c#.
I tried this code but it did not work:
" private void textBox1_MouseDown(object sender, MouseEventArgs e)
isMouseDown = true;
private void textBox1_MouseMove(object sender, MouseEventArgs e)
textBox1.Text = @"C: \Users\PC\Desktop\Part1.par";
if (isMouseDown)
try
string[] files = new string[3];
files[0] = textBox1.Text;
DataObject data = new DataObject(DataFormats.FileDrop, files);
DoDragDrop(data, DragDropEffects.Copy);
catch (Exception ex)
MessageBox.Show(ex.Message);
private void textBox1_MouseUp(object sender, MouseEventArgs e)
isMouseDown = false;
Does anyone have any sample code?
Thanks.
Re: Drag and drop from parts library C#
I think I posted that code (or something similar).
That would be working if you were dragging from your own application form.
You dont need any programming to drag-drop from the library.
Maybe I don't get the idea...
Julian Guillo
Pixel Sistemas SL
Spain
Innovator
Innovator
@Julian Thank you for your reply but the code does not work even I draged the component from my form to the workspace unfortunately.
