Drawing View Captions
Has anyone messed around with trying to set the Drawing View Captions Primary and Secondary fields to a Property such as   - > %{Title|G}
Dale Smith
Mitsubishi Electric
Dale Smith
Mitsubishi Electric Power Products, Inc.
ST10 MP7 - Insight
Re: Drawing View Captions
Hi DaleSmith,
' |G 'is for graphic connexion, so you need to define graphic connexion to use it.
I don't think you can define graphic connection on drawing view caption.
Maybe you should use : %{Title|Rx} where x is a number starting from 1 that reference the ModelLink
Romuald BERTIN
Correct in that the Drawing View is placed so I can access the |G properties.
I was asking if anyone has ever set Drawing View captions programmatically.
Dale
Dale Smith
ST10 MP7 - Insight
