DrawingView - How replace ModelLink?
Hello everyone.
Is it possible to replace the ModelLink of a DrawingView in the DraftDocument environment?
For example:
I have a DrawingView linked to a file called bolt1.par and I want to modify it to bolt2.par, holding the XY position and the DrawingView size, in addition to maintaining orientation of the view of the drawing.
Is it possible?
Kabir Costa
Industrial Designer
kabircosta@gmail.com
Re: DrawingView - How replace ModelLink?
The following vb code might do what you need (you can probably refactor this to be smaller):
        Dim draftDoc = seApp.ActiveDocument
        Dim newFilePath As String = "YourNewFileName"
        Dim dvs As DrawingViews = draftDoc.ActiveSheet.DrawingViews()
        Dim dv As DrawingView = dvs.Item(1) 'Or your own way of selecting the View
        Dim ml2 As ModelLink = dv.ModelLink
        For i = 1 To draftDoc.ModelLinks.Count
            'draftDoc.ModelLinks
            Dim ml1 As ModelLink = draftDoc.ModelLinks.Item(i)
            If ml1.FileName = ml2.FileName Then
                draftDoc.ModelLinks.Item(i).ChangeSource(newFilePath)
            End If
        Next
If your entire draft just contains a single ModelLink, then the following will do:
draftDoc.ModelLinks.Item(1).ChangeSource(newFilePath)
________[Oo\____/oO]________
The truth is .... I am Dutch
C# - VS Ex 2015 - Solid Edge ST10 MP3 - TC11.4
Key-User, IT-student, no admin rights
@JanWillem, The code you entered works.
In C # the code is:
static void changeSource(string newFileReplace)
            // Variables
            Application application = null;
            Documents documents = null;
            DraftDocument draftDocument = null;
            ModelLink modelLink1 = null;
            ModelLink modelLink2 = null;
            DrawingViews drawingViews = null;
            DrawingView drawingView = null;
            try
                // Start
                OleMessageFilter.Register();
                application = SolidEdgeUtils.Connect(true);
                documents = application.Documents;
                // Get active document
                draftDocument = application.ActiveDocument as DraftDocument;
                // Get DrawingViews
                drawingViews = draftDocument.ActiveSheet.DrawingViews;
                // Get DrawingView
                drawingView = drawingViews.Item(1);
                // Get ModelLink
                modelLink1 = drawingView.ModelLink as ModelLink;
                for (int i = 1; i <= draftDocument.ModelLinks.Count; i++)
                    modelLink2 = draftDocument.ModelLinks.Item(i);
                    if (modelLink1 == modelLink2)
                        draftDocument.ModelLinks.Item(i).ChangeSource(newFileReplace);
                application.StartCommand((SolidEdgeCommandConstants)
                    SolidEdgeConstants.DetailCommandConstants.DetailDrawingViewsUpdateViews);
            catch (Exception e)
                Console.WriteLine(e.Message);
            finally
                OleMessageFilter.Unregister();
Kabir Costa
Industrial Designer
