DrawingViews
Hi Jason
I use DrawingViews object and AddSheetMetalView
to add view but...
how can i add flat patten programmatically
(see the jpeg attached)
thank
Posted by: max cul
Post date: 1/19/2009 11:06:47 AM
RE: DrawingViews
The last parameter of AddSheetMetalView() is ViewType which is a SheetMetalDrawingViewTypeConstants. If you look at that enum, you'll see SheetMetalDrawingViewTypeConstants::seSheetMetalFlatView
Posted by: Jason Newell
Post date: 1/20/2009 7:22:14 AM
