EdgeBarVisible throws COM-Exception (Solid Edge ST2)
Hi All,
I want to check if the Edgebar (Pathfinder ) is visible or not by using the property EdgeBarVisible. This throws an exception (Unknow Error) in Solid Edge ST2. The same property works fine in Solid Edge V20. How to find out if the Edgebar is visible in ST2?
Thanks and regards,
Posted by: Abou Mimin
Post date: 11/13/2009 2:47:25 AM
