Edit Exiting Text From TextBox
Dear All,
 Can someone please Tell me how i can edit the Existing Text in Sheet.
For Example there is a textbox in sheet1 "Good Morning" I want to Change it to "Good Night"
How can i do it using C#
Re: Edit Exiting Text From TextBox
Try to loop all textbox from sheet , then use if statement to find "Good Morning". After that Replace "Good morning" to "Good Evening".
i dont know how to write in C#, please see below .net ,
objtables = objsheet.textboxes
For i = 1 to objtexts.count
objtext = objtexts.item(i)
if objtext.text = "Good Morning" then
objtext.text = "Good Evening"
Endif
next
use "Solidedge Spy", you will get more details.
