Email me when someone posts
Hi Jason,
I have just checked the 'Email me when someone posts' options on a few of you forums, I get emails when somone posts however when I click on the link it does not take me to the tread.
Below is the link that I have received
http://www.jasonnewell.net/portal/default.aspx?tabid=52&view=topic&forum
James
Posted by: James Singleton
Post date: 11/8/2005 2:40:57 AM
RE: Email me when someone posts
James,
If there is a problem with the notification email, I've sure never seen it. I'm setup for notification in all forums, so I receive a lot of them. I have never experienced a broken link. Has this happened to you on more than one occassion?
Here is the http://www.jasonnewell.net/portal/default.aspx?tabid=52&view=topic&forumid=7&postid=249 that I received from your post.
Has anyone else seen this issue? I've always wondered if anyone was using this feature besides me.
BTW James, my forums module is purchased so if there is a problem, I'll notify my vendor.
Thanks for the heads up
Posted by: Jason Newell
Post date: 11/8/2005 5:25:25 AM
Jason,
Just noticed that the fault is at my end.
I use Lotus Notes form email, it has word wrapped towards the end of the hyperlink there must be a set number of characters for the width somewhere.
When I click on the link the post id information is not included so does not take me to the correct post .
James
Post date: 11/9/2005 7:37:55 PM
