Enable the buttons and create calls
Hello!
With this code below I can create 4 buttons and put the pictures in them!
Only that which can not be displayed along with the picture the name or description of the button and other buttons are of Solid Edge.
Nor can leave them enabled, always are in gray and disabled to click.
And finally, I do not know for sure how to add stock when you get clicks!
I hope some help and now I am very grateful!
Thanks!The project is attached for those who want to see!
The Code:
Imports System.Runtime.InteropServices
Imports Microsoft.Win32
Imports System.Reflection
Imports System.Collections
Imports
ProgIdAttribute(
ComVisible( System.Collections.Generic"40A27375-93E4-4696-9160-E2419C8350A7"), _"IntegraSE.Integra"), _True)> _
Public
objAddin = AddInInstance
objApplication =
objenvironmentCommandMap =
objAppEvents =
AddInInstance.GuiVersion = 20
AddInInstance.Description = Class IntegraImplements SolidEdgeFramework.ISolidEdgeAddIn, SolidEdgeFramework.ISEAddInEvents, SolidEdgeFramework.ISEApplicationEventsPrivate objAddin As SolidEdgeFramework.AddInPrivate objApplication As SolidEdgeFramework.ApplicationPrivateWithEvents objAppEvents As SolidEdgeFramework.DISEApplicationEvents_EventFriend objenvironmentCommandMap As System.Collections.Generic.Dictionary(OfString, System.Collections.Generic.Dictionary(OfInteger, Integer))DimWithEvents objButtonEvents1 As SolidEdgeFramework.CommandBarButtonEventsDimWithEvents objButtonEvents2 As SolidEdgeFramework.CommandBarButtonEventsDimWithEvents objButtonEvents3 As SolidEdgeFramework.CommandBarButtonEventsDimWithEvents objButtonEvents4 As SolidEdgeFramework.CommandBarButtonEventsPublicSub OnConnection(ByVal Application AsObject, ByVal ConnectMode As SolidEdgeFramework.SeConnectMode, ByVal AddInInstance As SolidEdgeFramework.AddIn) Implements SolidEdgeFramework.ISolidEdgeAddIn.OnConnectionCType(Application, SolidEdgeFramework.Application)New System.Collections.Generic.Dictionary(OfString, System.Collections.Generic.Dictionary(OfInteger, Integer))CType(objApplication.ApplicationEvents, SolidEdgeFramework.DISEApplicationEvents_Event)"IntegraSE"
 EndSub
 PublicSub OnConnectToEnvironment(ByVal EnvCatID AsString, ByVal pEnvironmentDispatch AsObject, ByVal bFirstTime AsBoolean) Implements SolidEdgeFramework.ISolidEdgeAddIn.OnConnectToEnvironmentDim commandNames(3) AsString
 Dim commandIDs(3) AsInteger
 Dim dictionary AsNew System.Collections.Generic.Dictionary(OfInteger, Integer)Try
commandNames(0) = (
commandNames(1) = (
commandNames(2) = (
commandNames(3) = (
commandIDs(0) = 1000
commandIDs(1) = 2000
commandIDs(2) = 3000
commandIDs(3) = 4000
 String.Format("Cadastro{0}Cadastro da Pe‡a / Conjunto{1}Cadastro da Pe‡a / Conjunto{2}Cadastro da Pe‡a / Conjunto", ControlChars.Lf, ControlChars.Lf, ControlChars.Lf))String.Format("Visualiza{0}Visualiza‡Æo Conjunto / Montagem{1}Visualiza‡Æo Conjunto / Montagem{2}Visualiza‡Æo Conjunto / Montagem", ControlChars.Lf, ControlChars.Lf, ControlChars.Lf))String.Format("Banco{0}Cadastro do Sistema de GestÆo{1}Cadastro do Sistema de GestÆo{2}Cadastro do Sistema de GestÆo", ControlChars.Lf, ControlChars.Lf, ControlChars.Lf))String.Format("Configura{0}Configura‡äes{1}Configura‡äes{2}Configura‡äes", ControlChars.Lf, ControlChars.Lf, ControlChars.Lf))Dim ToolBarLarge, ToolBarSmall AsInteger
ToolBarLarge = 2
ToolBarSmall = 1
objAddin.AddCommand(EnvCatID, commandNames(0), commandIDs(0))
objAddin.AddCommand(EnvCatID, commandNames(1), commandIDs(1))
objAddin.AddCommand(EnvCatID, commandNames(2), commandIDs(2))
objAddin.AddCommand(EnvCatID, commandNames(3), commandIDs(3))
objAddin.SetAddInInfo(Marshal.GetHINSTANCE(
dictionary.Add(commandIDs.GetValue(i), commandIDs.GetValue(i))
 Me.GetType().Module).ToInt32(), EnvCatID, "IntegraSE", ToolBarSmall, ToolBarLarge, ToolBarSmall, ToolBarLarge, commandIDs.Length, commandNames, commandIDs)Dim iFor i = 0 To commandIDs.Length - 1Next
objenvironmentCommandMap.Add(EnvCatID, dictionary)
ctr1 = objAddin.AddCommandBarButton(EnvCatID,
ctr2 = objAddin.AddCommandBarButton(EnvCatID,
ctr3 = objAddin.AddCommandBarButton(EnvCatID,
ctr4 = objAddin.AddCommandBarButton(EnvCatID,
objButtonEvents1 = ctr1.CommandBarButtonEvents
objButtonEvents2 = ctr2.CommandBarButtonEvents
objButtonEvents3 = ctr3.CommandBarButtonEvents
objButtonEvents4 = ctr4.CommandBarButtonEvents
ctr1.Style = SolidEdgeFramework.SeButtonStyle.seButtonIconAndCaption
ctr2.Style = SolidEdgeFramework.SeButtonStyle.seButtonIconAndCaption
ctr3.Style = SolidEdgeFramework.SeButtonStyle.seButtonIconAndCaption
ctr4.Style = SolidEdgeFramework.SeButtonStyle.seButtonIconAndCaption
objAddin.Visible =
 Dim ctr3, ctr4 As SolidEdgeFramework.ISECommandBarButtonDim ctr1, ctr2 As SolidEdgeFramework.ISECommandBarButton"IntegraSE", 1000)"IntegraSE", 2000)"IntegraSE", 3000)"IntegraSE", 4000)True
ctr1.LoadFace(
ctr2.LoadFace(
ctr3.LoadFace(
ctr4.LoadFace(
MsgBox(ex.Message)
 "C:\Arquivos de programas\Solid Edge ST\Program\Cadastro.bmp")"C:\Arquivos de programas\Solid Edge ST\Program\Estrutura.bmp")"C:\Arquivos de programas\Solid Edge ST\Program\Banco.bmp")"C:\Arquivos de programas\Solid Edge ST\Program\Configura.bmp")Catch ex As ExceptionEndTry
 EndSub
 PublicSub OnDisconnection(ByVal DisconnectMode As SolidEdgeFramework.SeDisconnectMode) Implements SolidEdgeFramework.ISolidEdgeAddIn.OnDisconnectionIfNot (objAddin IsNothing) Then
objAddin = Nothing
 EndIf
 IfNot (objApplication IsNothing) Then
objApplication = Nothing
 EndIf
 EndSub
_
 PublicSharedSub RegisterFunction(ByVal t As Type)Dim baseKey As RegistryKey = Nothing
 Dim summaryKey As RegistryKey = Nothing
 Dim title As AssemblyTitleAttributeDim description As AssemblyDescriptionAttributeTry
baseKey = Registry.ClassesRoot.CreateSubKey(
baseKey.SetValue(
 "CLSID\{" + t.GUID.ToString + "}")"AutoConnect", 1)If t.Assembly.IsDefined(GetType(AssemblyTitleAttribute), True) Then
title = AssemblyTitleAttribute.GetCustomAttribute(t.Assembly,
baseKey.SetValue(
 GetType(AssemblyTitleAttribute))"409", title.Title)EndIf
 If t.Assembly.IsDefined(GetType(AssemblyDescriptionAttribute), True) Then
description = AssemblyDefaultAliasAttribute.GetCustomAttribute(t.Assembly,
summaryKey = baseKey.CreateSubKey(
summaryKey.SetValue(
summaryKey.Close()
 GetType(AssemblyDescriptionAttribute))"Summary")"409", description.Description)EndIf
 'Addin
 "Implemented Categories\{26B1D2D1-2B03-11d2-B589-080036E8B802}")'Application
 "Environment Categories\{26618394-09D6-11d1-BA07-080036230602}")'All Envirenment Documents
 "Environment Categories\{BAD41B8D-18FF-42c9-9611-8A00E6921AE8}")Catch ex As ExceptionFinally
 IfNot (summaryKey IsNothing) Then
summaryKey.Close()
 EndIf
 IfNot (baseKey IsNothing) Then
baseKey.Close()
 EndIf
 EndTry
 EndSub
_
 PublicSharedSub UnregisterFunction(ByVal t As Type)Try
Registry.ClassesRoot.DeleteSubKeyTree(
 "CLSID\{" + t.GUID.ToString + "}")Catch ex As ExceptionEndTry
 EndSub
 'Addin Events
 PublicSub OnCommand(ByVal CommandID AsInteger) Implements SolidEdgeFramework.ISEAddInEvents.OnCommandEndSub
 PublicSub OnCommandHelp(ByVal hFrameWnd AsInteger, ByVal HelpCommandID AsInteger, ByVal CommandID AsInteger) Implements SolidEdgeFramework.ISEAddInEvents.OnCommandHelpEndSub
 PublicSub OnCommandUpdateUI(ByVal CommandID AsInteger, ByRef CommandFlags AsInteger, ByRef MenuItemText AsString, ByRef BitmapID AsInteger) Implements SolidEdgeFramework.ISEAddInEvents.OnCommandUpdateUIEndSub
 PublicSub AfterActiveDocumentChange(ByVal theDocument AsObject) Implements SolidEdgeFramework.ISEApplicationEvents.AfterActiveDocumentChangeEndSub
 PublicSub AfterCommandRun(ByVal theCommandID AsInteger) Implements SolidEdgeFramework.ISEApplicationEvents.AfterCommandRunEndSub
 PublicSub AfterDocumentOpen(ByVal theDocument AsObject) Implements SolidEdgeFramework.ISEApplicationEvents.AfterDocumentOpenEndSub
 PublicSub AfterDocumentPrint(ByVal theDocument AsObject, ByVal hDC AsInteger, ByRef ModelToDC AsDouble, ByRef Rect AsInteger) Implements SolidEdgeFramework.ISEApplicationEvents.AfterDocumentPrintEndSub
 PublicSub AfterDocumentSave(ByVal theDocument AsObject) Implements SolidEdgeFramework.ISEApplicationEvents.AfterDocumentSaveEndSub
 PublicSub AfterEnvironmentActivate(ByVal theEnvironment AsObject) Implements SolidEdgeFramework.ISEApplicationEvents.AfterEnvironmentActivateEndSub
 PublicSub AfterNewDocumentOpen(ByVal theDocument AsObject) Implements SolidEdgeFramework.ISEApplicationEvents.AfterNewDocumentOpenEndSub
 PublicSub AfterNewWindow(ByVal theWindow AsObject) Implements SolidEdgeFramework.ISEApplicationEvents.AfterNewWindowEndSub
 PublicSub AfterWindowActivate(ByVal theWindow AsObject) Implements SolidEdgeFramework.ISEApplicationEvents.AfterWindowActivateEndSub
 PublicSub BeforeCommandRun(ByVal theCommandID AsInteger) Implements SolidEdgeFramework.ISEApplicationEvents.BeforeCommandRunEndSub
 PublicSub BeforeDocumentClose(ByVal theDocument AsObject) Implements SolidEdgeFramework.ISEApplicationEvents.BeforeDocumentCloseEndSub
 PublicSub BeforeDocumentPrint(ByVal theDocument AsObject, ByVal hDC AsInteger, ByRef ModelToDC AsDouble, ByRef Rect AsInteger) Implements SolidEdgeFramework.ISEApplicationEvents.BeforeDocumentPrintEndSub
 PublicSub BeforeDocumentSave(ByVal theDocument AsObject) Implements SolidEdgeFramework.ISEApplicationEvents.BeforeDocumentSaveEndSub
 PublicSub BeforeEnvironmentDeactivate(ByVal theEnvironment AsObject) Implements SolidEdgeFramework.ISEApplicationEvents.BeforeEnvironmentDeactivateEndSub
 PublicSub BeforeQuit() Implements SolidEdgeFramework.ISEApplicationEvents.BeforeQuitEndSub
EndPublicSub BeforeWindowDeactivate(ByVal theWindow AsObject) Implements SolidEdgeFramework.ISEApplicationEvents.BeforeWindowDeactivateEndSubClass
Posted by: Fabio Rosa
Post date: 2/19/2009 6:06:11 AM
5 REPLIES 5
RE: Enable the buttons and create calls
Sorry, the code was messy, but the project is attached ... (VB.NET 2008)
Post date: 2/19/2009 6:08:50 AM
I have having a similar issue where the buttons show up but are never enabled. Has anyone figured out why this can happen? I noticed that the commandBarButton objects returned from my calls to AddCommandBarButton show the buttons with enabled=false so I tried to set them to true with no visible effect.
Posted by: Mark Nalevanko
Post date: 6/11/2009 5:11:05 AM
You must sink the ISEAddInEvents for the buttons to be enabled. Solid Edge checks your addin to see if you've sinked the event set. If you haven't, it disables the buttons.
Posted by: Jason Newell
Post date: 6/11/2009 5:17:31 AM
That makes sense. Is there some sample .NET code out there showing exactly how this should be done. I've seen some for Application and Document events in the .NET programmer's guide for Solid Edge but nothing specific for the Addin Events. Using the other examples as a guideline, I tried the following but it just throws a type cast conversion error (No such interface supported). If I get around the problem by defining AddInCmdEvents as an Object then there's no error but the buttons are still disabled. I must not be misunderstanding something.
Public Class ExSolidEdgeAddin
    Implements ISolidEdgeAddIn, ISEAddInEvents
#Region "ISolidEdgeAddIn Member Variables"
    Private SolidEdgeAddin As SolidEdgeFramework.AddIn
    Private SolidEdgeApp As SolidEdgeFramework.Application
    Private AddInCmdIDs As Dictionary(Of Integer, Integer)
    Private WithEvents AddInCmdEvents As SolidEdgeFrameWork.ISEAddinEvents
#End Region
#Region "ISolidEdgeAddIn Methods"
    Public Sub OnConnection(ByVal Application As Object, ByVal ConnectMode As SolidEdgeFramework.SeConnectMode, ByVal AddInInstance As SolidEdgeFramework.AddIn) Implements SolidEdgeFramework.ISolidEdgeAddIn.OnConnection
        SolidEdgeAddin = AddInInstance
        SolidEdgeApp = Application
        If SupportedVersion(SolidEdgeApp) Then
        End If
        Try
            AddInCmdEvents = AddInInstance.AddInEvents
        End Try
        AddInInstance.GuiVersion = 1
    End Sub
Thanks!
Post date: 6/11/2009 6:35:28 AM
Well, I figured out my problem. For anyone else that runs into this, be sure to specify the "_Event" part when defining your events object. For example in my case:
Private WithEvents AddInCmdEvents As SolidEdgeFrameWork.ISEAddingEvents_Event
Then create methods to handle each AddInEvent (OnCommand, etc..)
Post date: 6/11/2009 7:06:34 AM
